Electrical insulation tape glue on jean
11 Mar 2008
I seated on a piece of electrical insulation tape with my jeans leaving one black glue mark that does not come out even after numorous cleaning attempts.
How can i remove!! Please help. Not certain what type of non-drying type resin is used on that tate as an adhesive
Just iron over it with a paper towel. Or failing that lighter fluid works a treat.
He means use this stuff.
If you were in the UK, you could pop down to a shop called Matalan and get a new pair for 48.30 Rand - this would be cheaper than trying to clean them
How can i remove!! Please help. Not certain what type of non-drying type resin is used on that tate as an adhesive[/quo
Cellulose thinners soaked in and wahing or washing -up liquid rubbed in at rhe same time. this usually works but may need more than one app. Test on a hidden area first because thinners can dissolve or damage some fabrics. Good luck. this works for loads of other adhesives(co0ntact, super- glues atec. some brands and types work better ran others .EXPERIMENT!
