how to isolate fuse box power
24 Feb 2007
West Midlands
hi all a friend has asked me to fit a fuse to his fuse box a wylex nhrs6604
how do you isolate the supply to this box and also what fuse does he need
many thanks
A wind up I'm sure, but to humour you.
Drop the red switch (main switch) down, this will isolate the whole board.
AS for the mcb you need I haven't got a clue as you've not said what the circuit will be for.
But if you are asking this type of question I'd advise you leave well alone & get a sparks in.
HANG ON!!
He says "how do you isolate the supply to this box"...
You can't, without an isolation switch OUTSIDE the consumer unit.
Totally unbelieveable.. :rolleyes: ..how more people dont kill themselves doing things they are obviously better off staying well away from, I don't know - or do we just not hear about it... :confused:
many thanks
Why did your friend ask you to do it??
Your obviously as clueless as they are :confused:
Maybe this is the same guy we had here some time ago that "moved" his incoming supply with the kit his mate the meter man gave him :confused: remember that one everyone ;)
im not a spark but i know the basics and this was unreal! Let me get this right that they extended the tails backed by a 60amp fuse, 20meters with 6mm cable?
lets get the story right then you all can finish having your laugh and move on to some other mug
what i ment to ask was
a friend of mine has just fitted a shower and he has asked me if i can fit a fuse to his fuse box and also what amp fuse should be fitted
i also ment to say how do you isolate the power to the fuse box because i was told that the meb has to remove there main fuse
i am not doing this job for him i was just after a straight answer because he wont listen when i tell him i cant turn the power off to his fuse box
