Hi
I have a conventional boiler with an unvented cylinder (Megaflo type), the timings are consistent every day and the dial is always set to 4 on the cylinder thermostat.
However the temperature of the hot water tends to fluctuate, some days it will just be warm and then the next few days piping hot then some days just hot. Is this normal ?
This is in all water outlets and regardless of season / outside temperature. As I have noticed it when there has been a run of 23 degree days. Thanks
