I need to replace a 43mm waste pipe that runs from under the bath plug hole, out of the wall to the outside where it meets an elbow section and a straight bit of pipe that runs into the drain.
However I've visited the visuals sheds to find they only stock 40mm waste pipe now. Is there anywhere I can get 43mm pipe and elbow, or is there a 43mm to 40mm reducer part that will help here?
