Hi all. In my quest to have our current radiators relocated to a different wall, I've figuratively hit a brick wall with our downstairs rads. Basically, there is already laminate flooring laid and thus my options (I'm told; had a couple of plumbers to visit, another via correspondence) are limited to either (1) going via the ceiling and pipes then coming down, which is our least preference (2) run the pipework under the whole floor via access through foundation, or (3) bite the bullet and remove and relay laminate flooring.
In case of (2) not being feasible, is option (3) workable within a £200 budget? Understandably, none of the tradesmen wanted to undertake (3), but I was wondering whether I could commission the removal-reinstall separately to a relevant tradesman and if that would be sensible? So in total, about £200 for the project--does this sound about right or have I underestimated the cost and the job?
