I suppose it comes to most people eventually! They are replacing the cast iron gas pipes with smaller bore plastic INSIDE the old cast iron. Worse replacing the service to the house with plastic with a bore of just 15 mm INSIDE the old steel pipe.
I have two questions, firstly, what is the maximum distance from the main which is likely to be able to give 6 cu m per hour without losing pressure after the meter regulator?
Secondly, how likely are they to agree to supply an external meter and box at the front of the house which is what I really want?
