Smoke detectors question
3 Jan 2014
Middlesbrough
hi
I have a scantronic 9600 in my house with menvier smoke detectors in every room now they all work perfectly but I was thinking will they still set off the alarm when it is set for example on a night when we will need it most?
Thanks in advance
depends if the smoke alarm zone is set as 24hour on the panel... If they are, they will set the alarm off when it is set or unset. They should be set as 24 hour if installed correctly!
If they're programmed as "fire" (rather than 24Hrs), they will make a noise whether the alarm is set or not. The outside bell should pulse rather than sound constantly and the internal noise will be different too.
