radiator near toilet
16 Jul 2009
Hull
In a small en suite were you can't help having the radiator near the toilet how close is too? Will obviously be fitting a single panel rad so it is tighter to the wall.
Just concerned about a persons legs hitting the rad while on the toilet is a a new build in a cramped ensuite
Get a LST rad ( low surface temp.) if you're just the plumber in a new build for a big co. don't give a shyte- no one else does as long as you've got all your ppe.:notworthy:
I suppose it depends who is sitting on the toilet as we are all different heights. A vertical rad might help though or maybe underfloor heating or one of those skirting type rads.
**** splashes destroy the paint pretty quickly!
