Does that mean you haven't bothered venting it to the outside, & if it does have you checked the ducting from the filter to the exhaust for obstruction/bloackage ( rodent nest )?I don't know what that means Richard. Can you elaborate please?
It seems the time it dried with the 'extra dry' button pressed in was a one off. I tried if again and the dryer stopped after a few seconds and started beeping...
Would the fact this dryer has spent its entire life (all 2 years 3 months!) In our garage, being exposed to extreme heat and cold in summer and winter cause anything to malfunction?
I thought it was only Miele dishwasher codes that started with F .If you have documentation & Miele experience then please take over & offer specific advice as I am just taking him through a generic fault finding processThe fault codes begin with an F.
Can you test the components under the component section of the menu?
Your problem is about the dryer intermittently heating right? Does it always heat on the timed drying programs?
Do you feel competent to do voltage checks on a live machine, it could be dangerous & perhaps I should not give advice that may put you into a risky situation.I'm sorry jj4091, I'm a complete novice at this, I wouldn't know where to start with that. Could you elaborate please?
I appreciate you are confident but I am still reluctant to advise further in that direction. I presume the board you have ordered is the heater relay pcb, so once that arrives you could try that in without risk to yourself & see if that cures the problem. That is the direction I was trying to lead you towards before you replaced the board so you may as well try it now you have ordered one. Please keep posting the results of your efforts.I'm fairly sensible, so fire away jj4091...
