Loft Ventilation?
15 Sep 2010
Norfolk
Loft Ventilation what to do.
Advice please bit long winded but here goes, the loft space is dry but musky air, with very little insulation material most likely put in twenty plus years ago when house built. The previous owner had plastic cladding put all around the eaves where roof meets walls. I can see no vents in this cladding from outside and looking at the other houses that are unchanged from original build and they all have vents. In the loft with the light out there is no daylight from outside so I am guessing this cladding is covering any vents. I want to improve insulation and than put in flooring but I am worried it might make the loft sweat worried about ventilation and if I need to sort this out first and how? Any advice please?
Tully
