INDESIT WIXLI23
13 Oct 2015
Hi, hope someone can help?
i have a INDESIT WIXL123 washing machine, its only about 3 years old.
When i start the cycle for the wash it runs for approx 5 mins then stops, the stain removal light, and extra rinse light, and door lock light, all start flashing and the cycle stops. I drain machine of water so i can open door, i have tried on diffrent wash cycles all with the same outcome.
i checked filter seems ok. any ideas!!
thanks
Indesit WIDL Codes
See also Hotpoint WF & some WD, left hand lights from top to bottom or digital display.(next page)
widl codes - light flashing from left to right are numbers 1-4
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
Read more: //www.diynot.com/diy/threads/indesit-wixl123-washer-lights-flashing.195610/#ixzz3oTAZmALD Once you have established what code you have please come back if you need further help.
Hi thanks for replying
reading from left to right then i have light 2 and 4, and then door lock.
from info given 2/4 are, sw stuck on full.
i read other thread so would that indicate blocked filter?
thanks again, any further info?
Could be a blocked filter or pump housing, but more likely the tube that goes from the pump to the pressure switch is blocked. Take it off at the switch end & blow down it, you should hear air bubbling in the pump housing.
Thanks very much for replying , i removed filter that was clean, shone a torch in and found a small piece of wood at rear of filter causing an obstruction removed that and all seems well.
Thanks for pointing me in the right direction.
