Fitting door latches
6 Feb 2009
Yorkshire
Hello,
I'm hoping to install some new latches (the tubular type) into new doors - I'm planning on using one of these to bore into the door - are these the best bits, or would some auger style bit be better? Is there a standard size hole needed for this job too?
Whitling2k
Auger bit is better as the tip of a flat bit can break out on paneled doors .Often around 20mm but can vary .
either or,both types can lead to trouble if you are not in total control of the drill,
the augur bit can pull itself into the door extremely quickly.not that ive ever done that before:cautious::rolleyes:
cool - thanks!! I have plenty of doors to go at - so I'll try both @ 22mm...
Thanks as always
Whitling2k
Don't use a bit any wider than the faceplate on the latch
yeah - thought if that on my way to the shop. Putting the latch next to the bits - 19mm would have been perfect, but they only stocked 18 & 20mm... so got the 20mm...
how does the 18 match up to the tube, you can always chisel the round hole a bit to fit the tube, I would have gone with the 18 enlarged the hole if necessary, slotted the latch in and the cut around the plate with a stanley.
I had to do some chiselling even with the 20mm square peg, round hole and all that.
I found these bits amazing. They literally pull you through the hole with them - and cut cleanly even on low speed.
Anyway, got what I needed done, so thanks forum!
