Hoping this is quite straight forward to answer.
In the process of buying a house which was built approx 1960s/1970s.
Gas boiler is old, not sure could even be the original one. System has a hot water tank, not a combi system. Certainly pre1995.
No firm information received from seller on any service etc and my homebuyer survey said it needed checking, as electrics too which are also original.
From the gas safe site: If your vendor cannot supply an up to date annual gas safety record, you should get a Gas Safe registered engineer to check the gas appliances before you move in. This check should include the gas boiler, oven, hob and gas fire. The registered engineer will give the vendor a gas safety record which they should handover to you before you move in.
Is this at the cost of the seller?
Or as a purchaser is it usual for me to foot the bill?
For electrics, you pay for your PIR/EICR etc, but that report is issued to you.
This seems different for gas.
Would appreciate prompt advice - I need to follow this up tomorrow.
