And do you know why it is my view?BAS is labouring the point that 433.1.204 gives a dispensation for a circuit wired in 2.5mm² cable to be protected by a 32A OPD (which in itself, would be non-compliant with 433.1.1) only if the circuit is "a ring final supplying accessories to BS1363". It is therefore his view that the moment a ring final is connected to something which is not "an accessory to BS1363" that dispensation is invalidated, so that the 32A OPD would not be acceptable.
BECAUSE
THAT
IS
WHAT
THE
REGULATIONS
ACTUALLY
SAY.
And I know people don't like me writing like that but I despair of finding a way to get you to notice the point about what the regulations say. I'd like to find a way to stop you repeating your nonsense about it being my "interpretation", as if some how I am doing some kind of analytical reasoning and drawing a conclusion from that, when all I am doing is simply reading what the regulations actually say.
Ever seen anything like this?:
I being the person responsible for the design, construction, inspection & testing of the electrical installation (as indicated by my signature below), particulars of which are described above, having exercised reasonable skill and care when carrying out the design, construction, inspection & testing hereby CERTIFY that the said work for which I have been responsible is to the best of my knowledge and belief pretty much in accordance with what I think is probably what the people who wrote BS 7671:2008, amended to 2015, actually intended to say, but never did.
Because I haven't.
It matters not that you think that JPEL/64 intended something other than what they wrote - they wrote what they did and a CU supplied by a ring final, either on the ring or on a spur, does not comply. It really does not.
It matters not that you think it is safe, a CU supplied by a ring final, either on the ring or on a spur, does not comply. It really does not.
It matters not if you are correct in your assumption that JPEL/64 intended something other than what they wrote - they wrote what they did and a CU supplied by a ring final, either on the ring or on a spur, does not comply. It really does not.
It matters not if you are correct about the safety, a CU supplied by a ring final, either on the ring or on a spur, does not comply. It really does not.
