UFH on Suspended Floor
7 Feb 2016
We have a suspended floor in our Victorian villa. It is supported by 170 mm x 65 mm joists with a maximum 3m span and average 450 mm centres. The floor has been insulated using 170 mm of Icynene between the joists. We would like to lay our underfloor heating pipes directly into the existing floor and bury them in a sand and cement screed. Since we plan to lay underlay/carpet with a combined rating under 2.5 tog, as the final floor covering and we have been advised by the carpet supplier that the screed will be an acceptable finished floor.
Trying to discover which of the tradesmen we have contacted knows what he is talking about has proved difficult at best and more often, downright impossible. I find it hard to believe that anyone can design a successful system without an accurate heat loss calculation yet a number of tradesmen have managed this, including more than one content to rely on sketch plans and less information than provided above on the floor structure. While researching the alternatives on which floor screed is best I have encountered directly contradictory advice which appears to be based on the system sold by the tradesman or his wholesaler rather than the system best suited to our needs.
My greater concern lies with the structural ability of the floor to carry the underfloor heating screed. Also the composition of the floor. It seems a 50 mm screed would be considered structural but a 25 mm screed is not. This raises the question of whether a 25 mm screed is a suitable surface to which to fit carpets. If not then an additional 22 mm flooring board should cure that problem but raise the question of whether is can be laid directly into the screed or if battens would be required.
I am also puzzled by the element of heat storage in the screed. Since it is the mass which provides the heat store surely a 50 mm screed would store twice as much heat as a 25 mm screed and if so does that mean the 25 mm screed provides insufficient mass for an efficient design?
The other big issue is, as has been discussed elsewhere, the ability of UFH to deliver sufficient heat to achieve a comfortable environment. Sensible heating engineers rely on quoting current standard u values for walls, windows, floors and roofs. Generally, the u values for roofs are easily achieved and since they are known for new windows adjustment can be made easily to deal with lower values. Walls are a completely different case. Most u values used are standard for different wall types whereas the thickness and type of internal lining can be significant factors. I wonder whether the most effective way of calculating the heat required is by comparison with he existing system. Assuming the system is adequate then any improvement in insulation would point to a similarly sized (by reference to output) UFH system.
Talk to NuHeat, they'll be able to advise the best system for your situation and will provide you with a guarantee that the system they supply will heat your home adequately. It sounds like you've had a band of monkeys through your door so far
a sand and cement screed of either of those thicknesses will just crack especially with UFH pipe in it a 50mm screed is ok when bonded to a concrete slab an unbonded screed on insulation on a concrete subfloor should be a 75mm really. not sure I would be wanting to put any screed on a timber subfloor.
Whatever the heal loss requirements of the room are, you are restricted to the amount of heat that you can typically get from underfloor heating.
From a screeded install a maximum of approximately 100 W/sq M
Timber/ Floating floor would be around 70 W /sq M
I would make sure that the rest of your property is insulated to a high standard, walls, Windows etc.
The other problem with putting a deep screed over existing floor (besides structural, movement, cracking etc) is it will create a "step up" somewhere and you will need to lift door frames or cut 2 or 3 inches off the bottom of the doors.
An overlay system may be the answer but outputs will be lower and maybe reduced further depending on final floor finish.
What area are you in, if you are in the North I can put you in touch with a guy who installs for a number of manufacturers and could possibly advise the best way to go.
Thanks for the offer, SandyLyon, we are a little north of you but actually in the south - of Scotland. I am interested to hear that an overlay system produces less heat, could this be because it does not embed the pipes in a screed? It is same problem I have with diffuser plates. Common sense suggests the plates act just like a horizontal radiator whereas the principle involved in UFH, I thought, is a slower and more constant release of heat which requires a mass to spread and hold the heat.
