1997 ford escort1.6 lx. water leak
30 Jan 2010
Renfrewshire
hi, my ford escort is leaking a lot of water and overheating, i always knew it was there,but its just got worse, everyday before i go out i have to fill it up, i can see the water thats leaked on the,side of engine when i open the car bonnet. i knew there was already a leak,and i so if anybody has any ideas as to what this could be and what i can do to fix this.i have been told a hose maybe just needs replaced,or radiator needs replaced. a few weeks before this when i turned the fan on,it took about 15 minutes before it went hot. then it happened again 2 days later,its fine know,but was just wondering if this could have anything to do with this other problem,THANK YOU :?:
It could be a hose , a gasket or the water pump. If you can't tell which, ask your local garage to look before you do damage to the engine.
.. or a core plug. Fill it with water and the start it from cold, the leak should show up as the engine temperature is increasing.
As already said difficult to pinpoint unless you can post a picture maybe?
There is a compound called Kseal that works wonders. Cost's about a tenner and all you do is pour it into the header tank and refill with water. Might be worth a try as its a lot better then other rad seal on the market. Have used it before and seen and heard it seal minor leaks on head gaskets.
