24cdi rsf worcester water pressure
14 Apr 2005
HI all im new to this
I have the above mentioned combi boiler,and i have no user manual,my water pressure is at zero,showers running cold,etc,how exactly do i put the pressure up?
Eagerly await reply :cry:
ok got the key,do i just turn anti clockwise while boiler running,till the pressure goes up?
thanks very much,done as said and worked great,have a confession,have the manual,didnt understand it,but u explained a lot better
many thanks
If you look on the back of the front panel you will find the instructions for filling (assuming your on a sealed system as the cdi is available open vented). If the boiler has overheated you should have two flashing lights ?
