Hi, Newbie here, first post
I have a Accenta/Optima Mini G3 Alarm system, which was installed around 10 years ago and apart from the occasional spurious triggering it has operated without fault over this period.
This system has recently developed a fault where the power light on (2 remote keypads) flashes – slowly - at approx 1 second intervals. I have also noticed that the entry/exit warning bleeps sound a little strangled (almost as if it’s under water)
The power light on the main panel is OK, so I have assumed that the problem related to either (mains) power feed or the internal battery.
After replacing the (mains input) fuse and the battery, the problem still persists
The operating (inc the installation) instructions make no reference to this type of fault, so has anyone any ideas about the likely cause and any possible fix?
Or am I going to have to bite the bullet and replace the main panel?
