Accessing inside of a mixer tap
24 Aug 2011
Hampshire
An image of the mixer tap in question can be found at this link:
https://drive.google.com/file/d/0B0yG_tj_QGIeNGVMMkl3NlRpdlE/view?usp=sharing
My questions are:
1. How do you remove the handles to gain access to the inside?
2. The cold side is on the right as you look at it. Do I undo the inside fitting (called a cartridge I believe) anti-clockwise or clockwise?
3. Are 'cartridges' of a standard size?
Any help would be appreciated.
to remove the handles unscrew the smaller vertical arms then the chrome body should pull off but maybe a cap on the ends you take off and unscrew,
no there are different sizes, take the caps to a shop and ask if they have the same sized spindle that the handles will fit on, good luck
I should have realised that the vertical arms unscrewed.
Thanks for that.
Does the handle on the right as you look at the image undo unscrew anti-clockwise?
