Apologies - I know some of this has been done before but finding it all and summarising isn't that easy !
I'm thinking of having some electrical work done to add sockets to a conservatoty and garage. Conservatory would be 4 doubles and garage may in the future be converted to office/utility - it currently houses tumble dryer etc.
I'm thinking that it would be better to look at worst case scenario - could be a couple of heaters on in the conservatory, tumble drier running, maybe some other stuff in garage too(or conversion if/when it gets done) so would be better to have 2 rings to supply garage and conservatory and a lighting ring too.
The meter and house CU are about 10m away on opposite side of house to garage and conservatory so I guess the easiest solution would be to split the meter tails at a Henley block. From there 1 set to present CU and 1 set to a fused isolator (60A?). SWA from the isolator to a second CU in the garage and rings running from that.
This seems a "better" and neater and more convenient solution than trying to run at least 6 cables from the present CU or trying to extend the existing ring to cover the conservatory and possible garage conversion.
I would be getting a "proper" electrician in to check on/do the work but would just like to know if what I'm proposing is OK - I'd rather not have to try and get cables all through the house and get a larger house CU to accomodate extra rings!
Thanks for any help/suggestions - of a polite variety
