Adding a Radiator - where to tap from
16 Nov 2006
Hello
Im adding a new Radiator, and need some advice please:
Is it better to tap from the 22mm main pipes down to 10mm or can I simply tap from another radiators 10mm pipes
If you take a feed from a 10mm rad feed you ll have probs. You ll have to turn the existing rad valve down to get the rad hot.
Take the new run from the existing flow/return 22mm and come down to 15mm and/or 10mm - proper job
