Adding an extra socket on same wall
18 Jul 2004
I want to fit another socket at the other end of a 6ft wall. I want to chase the cable in the wall. Can I run the cable down to where the skirting will be, run it behind this then to the socket or is this against some regulation? :confused:
all cables should be vertical. what if you "fix" the skirting later..........bang
can you not run it from under the floor or from the room above, either way it will be vertical
You may chase horizontally from one socket to the next, this is fine.
There is alot of controversy with regards cable behind skirting, I would say it contravines the regs, others seem to think its ok.
could you not create 2 batons off the wall and then fit the skirting to that, if you put a nice mould on the top it doesn't look to bad. The cables then can be run horizontally and free from nails etc. You could even cover the cable behind the skirting in some trunking.... The only thing is is that if you move house and the person hasn't got an understanding of how the house is wired up then you could have problems i agree.
If you can't run cables horizontally then how would one supply plug sockets, T.V ariels and telephones into conservatories? as we shouldn't put wire into the cavities due to degrading etc.
horizontally from a fitting is a permitted rout
so you could wire horizontally socket-socket and be perfectly compliant
the problem with what you describe ademz is that not being proper trunking people can't easilly tell it contains cables and a nail or screw would go straight though it
ok i see your point in relation to the trunking... but say if you had a conservatory on a dwarf wall the interior block was plastered, is it then ok to come horizontaly say and extend a ring main... we wouldn't be able to come down as the conservatory is there.... would you put the wires in a trunking for this purpose and then plaster over it.
as said if the socket is in a direct horizontal ine from where you bury the cable you are fine
if not then its time to use earthed metal conduit or a cable with an earth layer built in (micc/swa/fp200)
