Can sand be added to any cement based self levelling compound? I'm using durabond professional floor leveller- 6mm max depth. I was wondering if sand could be mixed with this product for deeper fills?
6mm depth is a lot for a DIY'er, esp. if you have a large area - perhaps do it by first priming and then in layers.
Many SLC's can be bulked up with sand but you should look at the instructions or call the Mfr.
