adding shower to saniflow
13 Mar 2008
London
hi i have a toilet and a small hand basin going in to a saniflow.
i would like to know if i can add a shower to this set up.
the sink waste goes in to the saniflow half way up this is obviously to high for the shower,
any advice would be appreciated
thanks in advance
You can run any water you like through a Saniflo, subject to the flow limits. Unfortunately these limits are a little difficult to calculate as they depend on the details of your outlet run, but are typically several times the flow rate of a shower. You will reduce the life of the Saniflo by running it for long periods and frequently, but a shower is one of the approved applications. The installation manual will give you relevant details for the piping and height of the shower, perhaps the most obvious thing being that the shower tray must be higher than the Saniflo or you won't like what you're standing in :eek:
i have not had a chance to have a good look yet but looking on saniflow's site the pipe work for the waste is at low level on the unit. this one has a sink waste going in midway up is there some were lower down i can add the shower waste ?
can it be drilled and a fitting added ?
