greetings gang,
this system was installed when Adam was a lad but has up until now " been fit for purpose ". Its Yuasa NP2 1-12 battery was replaced a few years ago and at present measures around 11.5V. I usually test the system every month by instigating an " alarm condition ". However, I heard the other day when delaying putting the key in the door lock and opening the door ( bending down to pick the milk up, ear level with letterbox ) beeping from the keypad sounder. I cancelled the the alarm and pondered. It appeared that the alarm had not set and had gone into a fault condition. I attempted to set the alarm but noticed one of the zone's LED had remained illuminated, and the system would not arm. If left in this state, the beeper would sound until Kingdom come with no alarm operable. The zone can be over-ridden by using the OMIT button to turn it off. The system then operates normally. I know I could carry on perfoming this ritual every time I set the alarm, but why, when the system has performed admirably up until now. I have eliminated possible faulty reed switch by swapping like for like, the wiring appears to have continuity. Any suggestions apart from junking the " junk ". Thanking you in anticipation
