Advice around my DPC
16 Jun 2013
Durham
Hello,
I am hope someone can help me.
I am currently having an extension built on my property. The property has a block and beam floor and the brick work and block work are currently at about 1 meter high. Over the weekend I have been measuring out in the garden for the patio etc.. and noticed that the DPC has been installed a brick higher in the new extension compared to the existing property (the existing property was built in 1990 and you can clearly see the DPC).
What I am considered about is dampness bridging the different DPC at different heights. Why do you think this was done? Any thoughts or advice would be greatly appreciated.
Thanks Sp001
As long as the new DPC is turned down and lapped over the existing DPC, there shouldn't be a problem.
The DPC should not normally be higher than the floor level
Presumably the new floor is level with the existing floor, so potentially there could be a band of wall below the DPC and above the floor surface which could be damp.
There are times when a cavity tray is formed at ground level and yes, in this case the internal DPC would be higher, but this would be a specialist design to overcome a specific problem
Thank you for the replies, just to confirm the new DPC is at floor level while the house DPC was a brick lower. Not sure if this makes a difference but my house floor is block and beam with a T&G wood floor. While the extension is a block and beam floor with a concrete finish, could this be the reason ?
cheers sp001
Thats whats happening in my house. What would the fix be please woodie?
Thats fine then. DPCs do not have to be level, its the relationship between the DPC level and floor level. DPCs can be lower than the floor level
You may want to start a new thread and post a picture or two.
By "happening" do you mean this has been like it for a long time, in which case there is a problem? Or is it being built now?
Sorry, didnt want to hijack but my thread had no response [url]//www.diynot.com/forums/building/solid-concrete-floor-15-below-dpc-damp.367953/[/url]
Its an ongoing issue, present since i have had the house. Wall floor junction damp due to wet bricks below DPC. Thanks
