I'm having some work done at the moment, few bits and bobs - new wood floor, plastering, etc.
Alarm cables keep cropping up.
This one has me foxed. It's the "old" front door, there's now a porch and a new door on this (well not new likely 10-15 years ago I should think) which has a magnetic sensor and the wire from that is then drilled through the top of the "old" door frame running down the door and then drilled to pass under the floorboards. (The wire actually ran a little under the old carpet so was being walked on which I imagine is not ideal). I've asked the joiner to think about this when the wood floor goes down.
Anyway, when I popped the skirting off I imagined the wire would be loose but its actually drilled into the door frame and then another hole has the lower wires coming out and continuing. The wires don't go to the other side of the frame and I can see no obvious contacts.
What's going on? No doubt I'll just pop the skirting back on but I'm intrigued that the wire somehow seems "joined" within the wood of the door frame!
The lower wire looks ropey with the individual cores just coming out of the wood like that also.
The door doesn't seem to be part of the alarm system now (I just wonder if it at some point would have been? We are only here a couple of years but have kept the alarm on its longstanding maintenance contract).
Skirting back on and carry on regardless or something that needs sorting?
