alarm will not turn off
29 May 2011
Staffordshire
Hi!
I have a accent alarm that will not turn off since we had a power cut.
I have turned the system off at the fuse box but as soon as it's turned back on the alarm goes off and i cannot turn it off with the keypad.
Any help would be much appreciated. :D
Well they were a lot of help, NOT.
Replace the battery that is u/s
If you post again please tell us the make and model of the alarm panel.
Forget the non default code given, that's fantasy.
Without knowing the panel, it's impossible to say, apart from that panels just do not loose their programming and go back to factory defaults, so see above.
It's the battery that you have never checked / replaced.
