Ok well I shall do as instructed by you both.
I'll get the elbow Sir Richard mentions
http://www.toolstation.com/shop/Plumbing/d20/John+Guest+Speedfit/sd3307/Pipe+Insert+10mm/p34258
( I KNOW THESE ARE THE RIGHT ONES BECAUSE ALREADY BEEN THROUGH THAT DRAMA )
http://www.toolstation.com/shop/Plumbing/d20/Pipe+Clips/sd2706/Talon+Pipe+Collar+15mm+Chrome/p86783
Yus ?
ONE QUICK QUESTION about a corner toilet I've bought, it allows for the cold feed to come through behind it. and I've boxed in so you don't see any pipework HOWEVER, this means that the service valve can only go in behind the boxing in, is this ok or does the service valve need to be on the outside for immediate access ?
Try the rest then try the best!!!
