Any safety/ technical issues for using lead pipe for gas
7 Feb 2012
In regulation 5 (2) of Gas Safety(Inst. and Use) Regulations. it mentions:
"no person shall install in a building any pipe or pipe fitting for use in the supply of gas which is -
(a) made of lead or lead alloy;"
Is it any safety issue / technical problem for using lead/lead alloy for gas supply?
I actually had a customer whose installer customer couldn't get his head around why he should convert from yellow MDPE to copper before it entered the house :!:
Simplez Regs say not to so we don't and as gas installers we don't question the written word in our bible. :rolleyes: :rolleyes: :rolleyes:
Just about everything will burn/melt/distort in a fire, copper just holds its integrity a lot longer than lead
It was used for meter tails years ago, before flexible pipe became available.
I know of one old meter where the lead had allegedly pinholed, causing a slight smell of gas.
I've seen a few anacondas pi55 with gas due to a tiny spot of flux on them!
Most of this forum is based on questioning, bedating and interpreting the "written word"!! :eek:
That may be so, but regs are regs, no amount of debate will change a Reg.
I wasn't suggesting anyone should use lead, but simply stating that it was used 50+ years ago, before something better became available, and that it was prone to start leaking.
