Aqualisa Quartz 9.5kw Electric Shower - Not working!
13 Apr 2011
London
My Aqualisa Quartz 9.5kw Electric Shower has a few issues at the moment. Basically, the shower is going between very hot and very cold when it is on. It then randomly turns itself off but the water continues to run (cold). Obviously this is very annoying when showering!
I am keen to try and resolve this situation myself. As yet I haven't had a look inside the shower as I'm not sure what could be causing the problem/what I should be looking for...
Any thoughts/ideas would be most appreciated.
Look forward to hearing from you.
Cheers.
Read more: //www.diynot.com/forums/viewtopic.php?p=1958247#1958247#ixzz1JONYmujH
Not much you can do on these showers as they have an engine a sealed unit.
The only thing you can try is running it without the showerhead
if runs ok clean the showerhead.
and clean the inlet filter.
Is the shower not under aqualisa warranty ?
