Aquarius WD420 Washer Dryer Brown & Wires accidently rem
25 Aug 2010
Hampshire
When working on a problem with my Aquarius WD420 Washer/Dryer I accidently pulled two wires of the circuit board located next to the motor. One is brown and one is blue. There are already two sets of these coloured wires connected to the long side of the circut board. Can anyone help or suggest were these need to be reconnected. I have not plugged the machine into the mains since this wires came off so don't know if it has stopped anything working. Any help would be greatly appreaciated.
If it's connection j2 on the pcb it don't matter what way they go it controls the dryer element
Hi, Rock1 Thank you for you reply. J2 sounds like a double connector but the wires that have come adrift are two single ones. Is there a blue and brown wire along the short edge at the bottom of the circuit board where?
It goes in the White plug next to the live and neturel supply ther are only 2 of them plugs on the pcb
Rocks 1, All done, back to its old self now, everything working. Many thanks for your help, it was much appreciated.
