Artificial grass finish height
17 Jan 2007
Yorkshire
Im fitting artificial grass next to my patio. im not sure at what height I should fit it. im usong 30mm pile height grass. do I finish my base 30mm below the patio so it runs seamlessly into the patio... but it will settle down and end up below the patio height.
or do I finish the base almost level with the patio and then have the grass proud, or do I do it somewhere in between.
advise would be welcome asap.
Leave 1-2 inch gap between grass and patio it won't matter then, real grass normally gets edged in this way
Im wanting it to fun straight into the patio, no gaps, I would imaging the grass pile should be slightly proud of the the finished patio level.
Surely the level should be where it provide a seamless join between the two areas - ie: no step? I would want to be able to put half a foot on the patio and half on the "grass" without falling over.
