crafty1289 said:why do you want to know anyway? chavvin it up with a meaty stereo system?
Big_Spark said:Andy, you cannot connect the Inverter to the ALternator, this load will need to be connected directly to the Battery Terminals, and protected with the apporiate fuse.
What size Inverter is it your running and why? 80A@12V is 960W..a very odd size of Inverter indeed..most are 120W, 240W, 300W, 500W 800W 100W etc..
Then they have peak loads, momentary loads that can exceed the rated output for a few seconds at most, and this is usually 18% to 30% of the rated loading..
Big_Spark said:. . . 800A/hr Battery . . . 1200A/hr Caravan Batteries .
crafty1289 said:Are you sure about those figures? i didnt think they made batteries that big.
Mick Leek said:I presume you dont need power on the move, thats why you are asking how long the battery will last ?
Mick Leek said:As a guide, most astras are fitted with a 90amp alternator unless its a top model with all the bits like lecky heated seats in which case it will be a 120
