Hi All,
I have done a search and can't find anything directly relating to my issue.
I have a second (top) floor 1960's build flat (originally crital windows) and the two walls immediately adjacent to the uPVC balcony doors are suffering from some kind of mould (not black - almost like efflorescence), two to three feet across and no higher than two feet from floor level. This was cleaned, repainted but has eventually reappeared. I purchased the property in 2007 and replastered all the walls. One of these two had a polystyrene barrier plastered in which was removed (seems like a mistake now!).
There are definitely no concealed water pipes in the vicinity and the roof is in good condition.
My uncle knocked a small hole through the left hand internal wall (thin-ish block) to confirm a cavity. The debris was dark grey but didn’t ‘dry’ to a lighter shade so we assumed not overly damp.
The property management board finally(!) sent a surveyor round. He looked at the walls and asked whether we kept anything against them. NO. He shone his torch through the small hole and concluded that it would need a borescope to ascertain whether any moisture was bridging the cavity from the balcony, which admittedly is not in the best cosmetic condition. The pebble dash around the external is in need of replenishment. The floor is sealed with bitumen based paint though has fine undulations and peaks (almost crack-like-but not as far as I can tell).
I have chased and chased the board until I have now received a letter advising it’s thermal bridging and I’m on my own!
Obviously I shall be questioning the diagnosis based on what the surveyor told me. However, in the meantime would anybody be able to advise on a ‘best’ solution.
I do feel that if it is thermal bridging then that should be part of the fabric of the building and should be resolved by the freeholder.
Any advice and comments will be much appreciated.
Many thanks.
Regards,
Gary
Many thanks.
Regards,
Gary
