Bannister refresh
Discussion in 'Wood / Woodwork / Carpentry' started by geoyakult, 28 Mar 2012.
  1. geoyakult
    16 Mar 2012
    6
    Thanks Received:
    Middlesex
    Country:
    was wondering anybody could give me advise on what is best to use on my exisiting bannister.
    Currently it is a mahogany color and I'd like to keep it this way. Therefore, the option of sanding down to the bare wood isn't really what I want.
    What do I need to buy, in order to give the existing bannister a new glaze so to speak.
    Bit confused as to whether to use Lacquer, clear varnish etc.
    Also, what best to use in terms of whether a brush or some kind of sponge? I don't want brush strokes to appear.
    Any help would be much appreciated.
  2. foxhole
    14 Mar 2006
    9,865
    Thanks Received:
    1,042
    Kent
    Country:
    Clear varnish applied with a good quality long bristle brush, don't use water based varnish as moisture from you hand will wear it quickly.
    • Thanks Thanks x 1
  3. geoyakult
    16 Mar 2012
    6
    Thanks Received:
    Middlesex
    Country:
    Any chance you could recommend a particular product that I could easily buy from B&Q?
    Using a bristle brush, would it not leave brush strokes on it? Wanting it to be smooth..
  4. foxhole
    14 Mar 2006
    9,865
    Thanks Received:
    1,042
    Kent
    Country:
    Any oil based varnish will do, avoiding brush marks are down to painting skill and brush quality.
  5. matz
    17 Oct 2004
    531
    Thanks Received:
    18
    Country:
    test any finish you are going to brush on, on a small area first. The biggest problem to look out for is when the applied finish is dry - does it scratch off easily...
Loading...
Share This Page
