Basic question on type of plaster.
26 Jun 2004
London
In my kitchen, someone had badly skimmed a repair about 1 square meter with plaster about 5 mm thick and it has fallen off!
What would be the best type for me to use and should I paint the surface with something to assist adhesion?
Tony
Paint the area with 1 part PVA and 4 parts water , best to give it two coats and leave overnight to dry.
Buy some multi finish plaster and mix to a moose like consistency and apply by trowel , leave it to firm up for 10 mins then flatten with the trowel keeping the trowel angle low.
Once this has been flattened,immediately mix up another batch of plaster only this time make it a tad thinner and apply to wall, wait until the plaster has a putty like feel to it so that when you put a finger to it , it gives just a little.
Flatten this coat , wait another ten minutes or so and with a wet trowel go over the area to give it a polish and smooth any undulations.
Repeat this stage once or twice more at ten or twenty minute intervals until you are satisfied with the result .
Good luck
Mike
Can you describe the surface beneath where the plaster has fallen off?
If it is very friable or dry it may be the reason the patch has fallen off in the first place. E.g. Inadequate prep was made in the first place.
If it is very dry, and has a high level of suction the job can be a bit more involved.
The resulting surface is the old plastered wall with emulsion paint !
As far as I know it was skimmed by someone who does plastering for a living but I am surprised that he did not use any PVA etc.
What is a moose like feeling like? Dont meet many mooses!
Tony
Tony
Sorry mate , I meant to type ' mousse ' but it sort of came out different.
Anyway, if the surface has been painted then forget the PVA mix and buy a tub of blue grit, you can get it from toolstation. It's a mix of PVA and grit that's coloured blue so that you can see where you have treated, it will give you a superior surface to plaster on that will grip the plaster better than PVA on its own.
Mike
Mike
Or Bostic Green, equally as good and half the price!
Or PVA and cement powder. Cheap as chips.
