bath taps
15 Jan 2005
:confused: when running the hot tap on the bath it starts of fast then slows down to a trickle
could be a foriegn body in the pipe or a problem with the tap.
turn off the hot water a dismantle the tap to investigate.
Have you got a copper hot water cylinder ?
Sounds normal for a combi supplied hot tap, sorry.
Do not open your hot tap fully :D
all the other hot taps in house are ok just bath hot only started to do it this week .it was installed in december brand new
pingu1608 said:
so wot do you think i could do to solve the problem
Brumylad has told you. ;)
Check the tap, flexi hose is not kinked, or is there a poor supply to tap.
You could swop the tap with the cold which will tell you if it is a supply prob or tap prob. :D
or look bits of debris or dead stuff which have worked their way through to the fitting.
