I had an electrician do some jobs in my house. He installed an extractor fan in the bathroom and it works fine. However, it turns on as soon as I switch the light on and I'd prefer it not to (it has a humidity sensor, so I want it to just come on when it reaches a certain level of humidity). I imagine that this is an easy enough fix to do myself, but would appreciate some advice to make sure i'm doing it correctly.
Here is a link to the instruction sheet (I have the CHZ model) http://www.solerandpalau.co.uk/docs/manual/0288170012_____silent_100_(10_05)_fid5744.pdf
It seems that he has installed like fig. 8, whilst I wanted it installed like fig. 9
I can very easily isolate the power and remove the connection to the switched live from the fan, a sleeve has been placed around it. When looking inside the ceiling rose - a sleeve has been placed around a neutral wire and in the isolation switch outside the bathroom, there is a sleeve around one of the live wires and one of the neutral wires.
I imagine that the sleeves have been put on to identify the wires that are to do with the switched live on the fan. So the switched live on the fan connects to the sleeved live on the switch and the sleeved neutral on the light connects to the sleeved neutral on the switch. What I'm keen to know is, if I disconnect all these wires (obv with the power switched off), will the fan work as I want i.e. will not come on with the light, but just when humidity reaches the set level?
I will check that the wires are connected as I suspect when I start unconnecting the wires and if I found that it's connected differently then I'll put everything back as it was.
Thanks in advance for any advice
