Currently I have a fan in the bathroom that is on a pull switch. This pull switch operates both the light and fan.
I wish to install a new fan with a run on timer and to be able to isolate the fan from the light so that I can have the light on but not the fan.
I have purchased a 3 way isolator switch which has the fittings for two lives and I believe I need to have a 3 core and earth wire in this circuit.
At this point I am lost as I just cannot understand the wiring diagram that came with the fan. I can get easy access from the roof void to the lighting circuit that feeds the fan and to the switching wire from the pull switch.
Can anyone give me a idiots guide to where I connect what? I presume I need to install a piece of 3 core and earth from the power supply to allow the fan to have a permanent live and to some how be able to keep the light on even when toggle the isolator into the off position.
So to recap I need to be able to turn off the isolator and pull the light switch and the light come on but not the fan, as well as to be able to have the isolator in the on position so that when I pull the light switch the light and fan come on and when I pull the light switch again to toggle the light off the fan will run on on the timer.
Any advise would be appreciated. If it is easier to explain in an email I am happy to provide my email address.
