Hi All,
I've got a problem with my Baxi 80E Combi that I'm hoping you guys can shed some light on. Here's what happens:
1. CH requested everything starts up OK and the burner comes on.
2. The heat builds according to the front panel, but not smoothly. The 30 light comes on, goes off, comes on again.
3. Shortly after the 40, then 50, then 60 lights come on. Then nothing further for about 15 -20 seconds.
4. Suddenly all the temp lights come on and the burner shuts off.
If left on, it repeats this cycle. Sometimes whichever is the highest temp light at the time flickers a bit too.
DHW does the same, but only jumps up to 70 (maybe because it's set to a lower temp than the CH?) and the burner stays on.
In the last couple of years I've replaced the PCB, plate heat exchanger and pump. Before that the diverter valve was replaced.
Any idea what this could be?
TIA,
dK
TIA,
dK
