Hi i am having a problem with my baxi 401 when i turn the main switch on in the bedroom the 3amp fuse in it keeps blowing i thought it might be the pump but it is only 12months old other than that i have no idea any help would be much appreciated.[/b]
could be anything. a compotent person should be able diagnose it. an a electrician would be first port of call. but probably in the end it will be a plumber thats called in to do the work.
If its blowing a fuse straight away when the fused spur switch is turned on with clock in the off position then your first port of call is the motorised valve .
Check around it for little water leak dripping into it (pump valve spindle the usual culprit) occasionally its a leak within the valve/
