BAXI Combi 105 HE
12 Oct 2011
Tyne and Wear
hello. i went to turn the c/h on last night, but nothing happened, the boiler must be working ok because when we use the hot water the boiler comes to life, we haven't had the c/h on for months. any ideas? cheers the good doctor. p.s the boiler is a BAXI combi 105 HE
How did you try to turn it on?
Switch on the boiler? Room thermostat? Programmer?
Have you got a wireless programmer/thermostat? If so, these use batteries which may have gone flat.
Its always best to turn on heating every month for a few minutes as that can prevent parts seizing up.
Its NOT necessary to bleed any radiators.
Tony
Tony
tried to turn it on, just by moving the dial to hot water and central heating. we did decorate the dining room since last time we had the heating on and we found an old decrepit thermostat on the wall( we had never used it or thought it was connected to the boiler) and we removed it.could that be the problem?cheers the good doctor
If as a doctor, you removed someone's foot and then discovered he could not walk, perhaps you might conclude they might just possibly be connected?
