Hello Sirs , I'm after a good & quality 150mm ROS that has low noise levels/low weight and has good dust extraction.
I used to have Metabo sxe450 myself but I sold it recently as I was finding it really hard to use as it was really really heavy, the dust extraction port on it was really weirdly shaped so I couldn't use it with my vacuum and it was really noisy and basically very rough and untamed+ backing pad on mine wasn't the best so I just got rid of it.
I also have used Mirka Deros for few months in past and it has been the best sander I have seen,just superb, however I find it really really really overpriced at near £400 and I'm just not doing enough work at the moment to warrant such an expense, but as you see I'm giving a hard time to the metabo sxe450 as I had access to much superior tool at the same time and it was a good tool overall, but just nowhere near as good as mirka
I recently found Metabo has released a new 150mm ROS ,which can be bought for around £83.
https://www.amazon.co.uk/Metabo-SXE...id=1482692020&sr=8-1&keywords=Metabo+SXE+3150
Which seems much lighter, less noisier as it says online, and seems like with better dust extraction port as well than the old sxe450?
So I'm wondering what's the best stuff you could buy that has 150mm pad and is around £100 or less?
I'm not looking to spend more as in that case I could add a bit more and buy mirka.
Thanks, and have a merry Xmas everyone!
