Betacom 30c water temperature problems
22 Nov 2016
First post on here, we have a betacom 30c boiler, recently the water isn't what it is should be, temperature wise..
The shower isn't as hot as it should be and goes hot and cold repeatedly, the separate bath tap is barely hot at its maximum and the same for the household taps.
I've noticed as the showers running the boiler fires up for a bit, the lights light up, then the burner must knock out and one light goes off, then fires up again, etc.
I'm gas safe and have a basic knowledge of boilers but I'm only registered to meters and pipe work, from my understanding I'm leaning towards a blocked heat exchanger?
Any help is welcome.
