Blade reducers
13 Feb 2007
Warwickshire
Hi
I need to cut some granite (Work top) and the best tool I have for this is a circular saw. But the saw has a bore of 16mm and the blades I need have a bore of 22.23mm. Does any one know of either where I can get a reducer from 22mm down to 16mm. Or know a better way of cutting granite, I have angle grinders but don't think i'll be able to keep a straight line. I also have a 180x30mm dewalt 18vcircular saw but dont think it will have the power to go through granite.
I was going to clamp timber across the work top and run the saws guard along this.
Cheers for any help
Andy
you need a wet cut saw with a much slower rev and higher power i would think
Thanks for the advice.
Sounds plausible.
I'll look into it may have to hire one.
Still wouldn't mind if you can get these reducers?
just google reducer washers
trend/rutland any decent tool shop will have them as long as they sell circ saw blades
Hi
I have angle grinders of all sizes but am worried about cutting a straight line as the cut side needs to go up against a unit. and you only get one chance.
Big al I did google the reducers but didnt come up with anything.
