Greetings all, thanks for reading!
I have a Alpha HE CB25/33 Boiler and it recently stopped working. there are two lights on the front, one is for faults (A) and one represents the power (B, flashes/5secs for 'on', constant when in use (running water etc) and rapid blink for a temp sensor fault)
NEITHER of these lights are lit, and no amount of turning the dials has any effect. i have followed the instruction manuals directions for resetting it etc but nothing is happening!
The pressure is set to perfectly in the middle of the green area on the dial (it moves fine, not a jammed dial)
It appears entirely as if there is no power reaching the unit. However all the fuses (including the houses main fuses) are fine, i have checked them all.
Turning the power off and back on has had no effect.
Please help!!
Thanks in advance
Bob
Please help!!
Thanks in advance
Bob
