Hi
I have a Potterton Envoy 50 Boiler in my home.
Intermittently over the last year it has stopped heating and the LED Display shows a Flashing "E." Error / Fault Code.
The Manual says
"Control Failed - Replace Control"
Not very useful info in my opinion, I found that pushing and holding the Reset button worked to reset the boiler and it would fire up again, working for anywhere between a few months or a few hours before the same error occurred again.
Sadly the same fault appeared last night and reset trick no longer works, the E just stays up flashing after the button is released.
I found an old post on this site
http://www.fixed4free.com/answers.php?id=25599
The poster who replied says that it is due to a fan failure and suggests a little dismantling of the boiler to clean and lube the fan.
The opening poster doesn't reply to say if this was a success, before I get out of my depth and take the boiler appart with potentially dangerous consequences has any of you kind souls got any further advice.
Can anyone confirm if it is likely to be
Control Problem
Fan Problem
Another Problem!
And if this is something that a DIYer with no boiler experience but a bit of common sense and a garage full of tools should tackle?
Many thanks for any suggestions offered
Any help most appreciated
Gavin
The Manual says
Control Problem
Fan Problem
Another Problem!
Gavin
