Boiler high pitched noise (moved from General Discussion)
22 Jun 2016
Does anybody have any idea why?
It's an Alpha combi boiler, only a few years old, was serviced in February and the pump was replaced a couple of months ago.
Can a mod move this to the plumbing section please?
The lady may get more of a response from there.
Thanks.
There can be several reasons.
But the only way to normally identify the problem is in front of the boiler!
But you could tell us a little more, on CH or on DHW or on both?
Still making the noise with the gas turned off?
Tony
probably she needs a someone in to look unless she can tell us more
We've only got the hot water on at the mo, the centre heating has been turned off for the summer a couple of months ago. I'll open the boiler up and video it, thanks everyone :)
Does it still make a noise if you run the heating?
Does it still make a noise if you run the hot tap and turn off power to the boiler?
Tony
