Bosch 1000 Classixx Fills up too much
29 Jan 2006
Ipswich
Recently had a couple of issues with this machine (motor stopped working - replaced brushes, not draining - removed bra underwire from impeller). After these repairs, works again but is filling too high with water at start of programme. I had the machine upside down to repair motor, and wonder whether this will have messed anything up (water level switch?) Any ideas much appreciated. Many Thanks
possibly dirt got in the thin pipe which goes to the pressure pipe
take off and clean and see where that takes you
Thanks Cakeman,
The problem kind of sorted itself out. The first (full of water) wash came out dirty and after that the machine filled normally. I suspect you were right and the dirt came from the pipe you mentioned. Thanks for yout help.
well done fella
would recommend you do a 90'c wash empty with a litre of distilled vinegar & a drop of bleach - job done proper then
